Gurgling noise on startup
Old May 11, 2005 | 03:04 AM
TheJazz7's Avatar
Default Gurgling noise on startup
Hi,
So I've noticed a "gurgling" noise coming from the back of my A4 after I turn the ignition. I think it only happens when the engine is warm, but I'm not 100% sure about that.
After I start the engine, there's a fluid-sound coming from the back...it usually lasts about 5-10 seconds, then stops. It doesn't change if I rev the engine, or if the car is in drive/reverse. I'm thinking it's some kind of issue with the fuel pump or filter. Any thoughts on this?
Thanks!
Old May 11, 2005 | 01:06 PM
jukeit's Avatar
Default RE: Gurgling noise on startup
I think it's likely your fuel pump kicking things off until your fuel pressure regulator and engine work together to keep the fuel circulating. That's my guess, but someone with more experience should chime in on this one.
Old May 11, 2005 | 07:03 PM
Jestnomen's Avatar
6th Gear
http://www.audiworld.com/tech/misc8.shtml
Old May 11, 2005 | 08:31 PM
TheJazz7's Avatar
Awesome, thanks Jest!
and for the record, I searched before I posted...my bad for using "gurgling" instead of "gargling"
Old May 12, 2005 | 01:38 AM
Jestnomen's Avatar
6th Gear
haha, yeah get it right!
mstorey20
Dec 6, 2012 11:27 AM
betyouaint
B7 Models
Mar 13, 2011 05:36 PM
A4Steve
Jun 10, 2007 02:31 PM
Mary#17
Apr 3, 2006 04:36 PM
owdios
Sep 30, 2005 08:49 PM
