Having fuel problems, i replace fuel filter and fuel pump
Old Nov 23, 2013 | 11:48 AM
skihigh2299's Avatar
Angry Having fuel problems, i replace fuel filter and fuel pump
HELP I replace the fuel filter and fuel pump on my 2002 a4 1.8t and I still have the same problem, the fuel filter makes a weird noise, and then the car shuts off like it does not have gas. what could be the problem? my original problem was that the car would run fine for 20 min or more but then it would stalls like fuel pump gives out but I put I new fuel pump on, and still does the same thing help pls
Old Oct 11, 2015 | 02:41 PM
AudiCharlie's Avatar
Agree with M5S5. Before doing ANYTHING, I would take the car down to an O'Reilly or other auto parts store and have them do a diagnostic check. They will do it for free and print out a full report for you. Even if check engine light isn't on, the car's computer may still give you some codes to give you an idea as to what might be wrong. Without knowing exactly what the issue is, you could be wasting a lot of money replacing parts that don't need to be replaced. My recommendation is to find out what the problem is first, whether that involves taking it to auto parts store or a certified Audi repair shop, then you can replace the parts needed to fix it.
Old Oct 11, 2015 | 05:54 PM
dave944's Avatar
Being that the original post was from 2 years ago, I think he may have gotten it sorted out. I hope. But for anyone experiencing this issue you might want to check the hose running from the pump to the tank bulkhead where the external fuel lines attach to the tank. I had a crack in the line just at the crimp up at the top and that was allowing the fuel pressure to drop and air getting into the lines. I cut the crimped part off and replaced the entire hose. When replacing the hose make sure you use SAE 30R10 hose. Regular EFI fuel line will not suffice because there is no fuel resistance built into the outside surfaces like the inside.
<a href='http://postimg.org/image/5lykdyhh5/' target='_blank'><img src='http://s20.postimg.org/5lykdyhh5/DSC01373.jpg' border='0' alt="DSC01373" /></a>
<a href='http://postimg.org/image/veyfabfnd/' target='_blank'><img src='http://s20.postimg.org/veyfabfnd/DSC01374.jpg' border='0' alt="DSC01374" /></a>
<a href='http://postimg.org/image/cb53tz2t5/' target='_blank'><img src='http://s20.postimg.org/cb53tz2t5/DSC01375.jpg' border='0' alt="DSC01375" /></a>
<a href='http://postimg.org/image/q29kw6rqx/' target='_blank'><img src='http://s20.postimg.org/q29kw6rqx/DSC01376.jpg' border='0' alt="DSC01376" /></a>
skihigh2299
Sep 25, 2015 12:09 AM
DJmart
Aug 3, 2013 11:08 AM
sollyd25
Dec 2, 2011 07:39 AM
elye1231
Jun 20, 2011 08:56 PM
SmoothTT
Oct 9, 2009 08:10 PM
