Heater issue on 2005 A6
Old Dec 22, 2012 | 04:11 PM
tpurchal's Avatar
Default Heater issue on 2005 A6
On an intermittent basis, the outside vents will blow super hot air. Cold air will blow in middle vents, but outside vents (driver and passenger) blow hot. I live in Dallas and this has happened on 100 degree days as well as 50 degree days. Very annoying. Unfortunately, it is an intermittent problem and is always working properly when I am near a dealer. The problem is not getting worse. Happens about once a week. Is this a common problem? Easy to fix? I will assume it will be expensive to fix.
Old Dec 22, 2012 | 08:45 PM
SilverSline's Avatar
Yes, pretty common issue. There is a valve that regulates coolant flow under the hood in the cowl area. These go bad sometimes and cause erratic vent temperatures.
Old Dec 25, 2012 | 02:35 PM
tpurchal's Avatar
Thanks for the reply. But to be clear, both outside vents near the doors blow really hot air while the center console vents will blow cool air. Does your response still apply?
Old Dec 26, 2012 | 08:41 AM
Yes, I would still look at replacing that heater valve and those symptoms you described are pretty common when that part fails.
Let me know how you make out.
bbeach
Jan 30, 2010 02:16 PM
wcrowder
Oct 4, 2009 10:21 PM
jbooker
B7 Models
9
Jan 23, 2009 11:08 AM
charlie4616
Sep 19, 2008 04:28 AM
smootboy5
Dec 24, 2007 01:18 AM
