help with mass air flow sensor
Old Oct 16, 2008 | 11:59 PM
rplets15's Avatar
Question help with mass air flow sensor
Hey guys i just bought a 2000 a4 1.8t about a month ago and so far love the car but the mass air flow sensor is bad on it and i need a new one i tired autozone but they were just a waste of time and ive ended up having to go get the part from the dealership its gonna coast $250 so i wanna put the part in by myself save as much money as i can now the prob. is idk how to ive looked at the part and was just confused as hell its all so compact in there can anyone tell me what i have to do to replace it and if you had pictures that would be amazing but what ever you can do to help would be apriciated very much!! thanks!
Old Oct 17, 2008 | 12:30 AM
AutoUnionFan's Avatar
I don't know about $250 for a MAF since I've havnt bought one yet. But I have cleaned mine. To replacde it you need to open up the box that encloses the air filter. You should see the sensor inside. Some tabs or something hold it in place. Pop it out and put the knew one in. Make sure you dont contaminate the sensor but touching it or anything else. Should make a nice difference.
Old Oct 17, 2008 | 12:44 AM
rplets15's Avatar
is it in the box by the air filter cuz everyone ive talked to said it was down in the bottom right corner of my car
Old Oct 17, 2008 | 12:54 AM
nope its in the air filter box. open it up and take a look, should be a 15 min job
Old Oct 17, 2008 | 01:01 AM
rplets15's Avatar
**** dude then should i go back to nappa to get the part cuz i didnt use it before cuz it didnt fit obviously i was trying to put it in the wrong spot tho or should i go to the dealership and get the real thing?
Old Oct 17, 2008 | 09:55 AM
s4tech's Avatar
$250 at the dealer sounds high though some Audi dealers have MSRP + x%- called volumetric pricing- Retail SHOULD be abt $210 at the dealer and they are typically rebuilt by audi but there is no core charge. The unit in your car whether its an AEB or ATW engine is a Bosch- We get abt $168.00 for the air mass meter.
The replacement is pretty easy. Pull the WHOLE air box and remove the top half. You CAN take the top half of the air box off with the bottom half still in the car but it can be difficult to get at the rear clip close to the fire wall. The air mass meter is fastened on the inside with 2 screws- may be phillips head or torx bit- probably a torx but i've seen both. HIGHLY reccomend a new air filter when you replace the MAF and vacume debris from the air box.
Old Oct 17, 2008 | 10:31 AM
CRAZYHAWK's Avatar
Old Oct 17, 2008 | 11:58 AM
rplets15's Avatar
thanks a bunch but how do i tell what kind of engine i have if its an oem-aeb, oem-atw, or a oem-awm?
Old Oct 17, 2008 | 12:21 PM
On my car (2000 a4 1.8t) the engine type is engraved on the engine - in the front, above the timing belt, just sticking out past the engine cover. There are other easy ways to tell such as the VIN number.
Old Oct 20, 2008 | 07:15 PM
Darkprodo's Avatar
you should have an AMB
tuga.A4
Jan 9, 2013 06:35 AM
LKaler
Apr 26, 2010 09:43 PM
abedel2
Feb 7, 2010 07:57 PM
Nick_UltraSport
Feb 9, 2009 10:49 PM
fromerich
Nov 10, 2006 10:05 PM
