How to Locate Gear Oil and re-fill it?
Old Jan 7, 2007 | 04:34 AM
useman77's Avatar
Default How to Locate Gear Oil and re-fill it?
Dear All,
I need a clue where to find the Gear Oil Gauge (to see the level) on Audi A4 1997 1.8lt ? Recently my car is having gear problem (jerking) and I want to see the gear oil level, may be its already low and re-fill it. So anybody have an idea?
Please..please..please...
Thanks,
Yus
Old Jan 7, 2007 | 11:58 AM
techbod's Avatar
Default RE: How to Locate Gear Oil and re-fill it?
there is no dipstick for the gearbox they are so they say filled for life heheheh if you believe that, I doubt that's your problem though any CEL on?? is it auto or manual??
Old Jan 8, 2007 | 03:00 AM
SAudi's Avatar
that may not be the problem, but if you just want to locate the drain/fill for s!its and giggles.its right under the tranny, you cant miss it. its the one bolt you dont have a tool for. you can get it on ebay for 20-30 bucks. as for the fill plug its a 17mm bolt behind the driver side front axle. you can find it by feeling around. BTW this is only good for a manul. there is also a post with pics in the DIY section.
Old Jan 8, 2007 | 04:01 AM
useman77's Avatar
it's an auto tranny...
the real problem is everytime i run the car just about 5 sec it couldn't run smoothly and it's like too hard to change to 2nd gear, more over if i run the car without warm up it will be difficult to run, but if i warm up the car for more than 15 minutes i could run the car better, i always check beneath the car and there is no leak at all except water may be from the AC.
if as you (avant80@2.6) said that it's filled for life then i have to change the gearbox?[:@] ugh BIG money... but any body experience with this problem? will it be better if i change the gear oil only?
Old Jan 8, 2007 | 04:31 AM
useman77's Avatar
One more thing... is on DIY for auto tranny as well? ( B5 5 spd tranny fluid change by Sandman)
What kind of oil I should use?
Thanks again...
Old Jan 9, 2007 | 03:00 AM
SAudi's Avatar
the jist of it is the same but look up other forums for correct amount to put in. royal purple or mobil 1 synthetic automatic gear fluid is the oil of choice.
andrewk24
Mar 25, 2008 08:23 PM
a6lovely
Dec 11, 2006 04:43 PM
MeadowsMD
Feb 5, 2006 06:15 PM
star
Jul 19, 2005 09:36 AM
ssss
Apr 26, 2005 06:31 PM
