ignition control module install
Old Apr 1, 2008 | 05:37 AM
PRican1.8T's Avatar
Default ignition control module install
okay, i've been looking all over here trying to find an install for a 2000 A4 1.8T and i have not been able to find it. does anyone know where it is, how to remove, and how to install the new one? also, anyone know where to find a cheap on? i found one on ebay for about $80. is that the cheapest? thanks! (also, is it hard to do?)
Old Apr 1, 2008 | 07:44 AM
PRican1.8T's Avatar
Default RE: ignition control module install
i saw a picture of where it's supposed to be but here's the weird thing... i don't have anything there! it's just the metal plate with the two holes to screw in my non-existant ICM! there are no loose wires, so where is my ICM if i even have one?!
Old Apr 1, 2008 | 08:46 AM
zat0rsk1's Avatar
yo its super easy. im pretty sure its the module located above the airbox. i replaced mine and it took 5 minutes.its two screws and when you put the new module one on , make sure you have that contact glue. The package you buy probably comes with it , so put some glue down on the metal before you place it back on, ( youll kno wut im talking about when u see it)
Old Apr 1, 2008 | 11:10 AM
CRAZYHAWK's Avatar
You don't have an ICM.
Old Apr 1, 2008 | 05:08 PM
PRican1.8T's Avatar
so then what am i supposed to do? my car's shaking on a cold start. a rough idle and i replaces the fuel injectors, the spark plugs, the coil packs, AND the ECTS this past weekend! what's wrong with it?!
Old Apr 2, 2008 | 09:18 AM
CRAZYHAWK's Avatar
Read the codes, and post them.
Old Apr 2, 2008 | 02:41 PM
PRican1.8T's Avatar
it's p0301-p0304=misfiring in every cylinder, but i've already replaced it att except spark wires and MAF sensor. i was gonna replave my ignition control module, but i don't have one! what do i do?!
Old Apr 6, 2008 | 01:00 AM
PRican1.8T's Avatar
bump
Heber
Jan 19, 2010 05:01 PM
kiellish
Mar 4, 2009 02:35 PM
georger
Nov 17, 2008 06:08 PM
Belligerenceā„¢
Jun 24, 2008 10:16 PM
a4anonymous
Jan 5, 2006 05:37 PM
