Losing power, EPC light, 03B9 cylinder over pressure code?
Old 07-14-2016, 11:25 AM
Ker Chenk's Avatar
Default Losing power, EPC light, 03B9 cylinder over pressure code?
2013 Audi A4 1.8 TFSI
50K miles
CJEB engine
EPC light comes on when accelerating. Sudden loss of power which remains until engine switched off. Probably disabling a cylinder though not confirmed.
EPC light goes away and power resets to normal when ignition switched off and back on.
On one occasion completely lost power while running at constant 60 mph after EPC came on. Reset OK after stop.
Not consistent
• may trip at 30mph or 70 mph under slow acceleration
• may not trip at all under maximum acceleration to 70mph and redline
• may trip at 3K rpm, may trip at 6K rpm.
• seems easier to trip when car has been running for a while
Engine fault code 03b9 overpressure on cylinder 4?
Sensors reporting OK
Have shuffled plugs and coils around
Have run jet cleaner through
Not finding anything relevant via google. Anyone any ideas, or even know how the car would work out an overpressure condition on the cylinder?
Tia for any info.
Ker
Old 07-14-2016, 12:41 PM
dave944's Avatar
When did OBD Codes go Hexadecimal? 03B9? Are you sure that's not 0389? That would be a crankshaft sensor and make more sense.
Old 07-14-2016, 03:58 PM
Ker Chenk's Avatar
Definitely 03b9
Old 07-15-2016, 09:52 PM
dave944's Avatar
No idea, man.... Direct injection engine?
Old 11-16-2016, 06:46 AM
Ker Chenk's Avatar
So some progress ....
Audi garage said coked up. Had a decoke to no effect. Audi replaced fuel pump and injectors - no effect. Insisted must still be coked up then. Claimed could be caused by carbon on inlet valve and recommended complete strip down. New engine would be cheaper.
Independent garage put camera down into cylinder - clear signs of detonation on the cylinder crown. Don't see now this could be caused by coke on inlet ports so -1 for audi main dealers and audi product support.
Most causes of detonation (thermostat, egr, turbo) that I can read up on would affect more than just one cylinder. Suspect other fault or manufacturing defect. Any ideas?
Will try some lower temp spark plugs and higher octane fuel in the meantime.
Old 07-23-2018, 01:18 PM
Ker Chenk's Avatar
10K miles later engine gives up. Went for engine rebuild. Both cams and both Vanos kaput, punched hole in cylinder head. Had to replace entire head.
@audi not impressed, must have been manufacturing fault.
Old 07-24-2018, 09:25 AM
Kareem Farhat's Avatar
pretty shi**y deal man...
I have an 07 3.6 Q7 and the timing chain just went on me. 200k miles on it. I think im going to try a **** around and see if i can replace it in my garage. but i hear i need to pull the engine out lol
snatchman
01-06-2012 11:38 AM
frustrated1
05-19-2009 07:30 PM
reynoldsr
05-13-2009 03:53 PM
pete7
03-11-2008 03:04 PM
NuYorka103185
04-21-2007 10:44 AM
Quick Reply: Losing power, EPC light, 03B9 cylinder over pressure code?
