misfire detected on cylinder #1
Old Nov 2, 2007 | 07:52 PM
dgirlsdemsugar's Avatar
Default misfire detected on cylinder #1
Okay here's the scenario, one day my car went into limp, ruff idle with flashing CEL. I swapped around a new coil pack in every cylinderand nothing changed. By the way it's a 99.5 1.8T fwd tiptronic. I purchased a cheap code reader and as suspected it said misfire detected, the following code told me cylinder #1 was the bad cylinder. I tried swapping coil pack#4 with #1, no change it still said cylinder #1 even after I cleared the codes. So if it's not a bad coil pack what else could possible cause these symptoms? Thanx in advance
Old Nov 3, 2007 | 11:33 AM
dankhound's Avatar
Default RE: misfire detected on cylinder #1
Most likely a bad ignition control module on the airbox. Could also be a bad injector or a mechanical problem with the engine compression.
Old Nov 9, 2007 | 06:55 PM
Great Job!!! the problem turned out to be the ICM.
Russ Heinrichs
Aug 18, 2021 12:39 PM
Maxmillion
Apr 8, 2011 12:26 AM
dhypnotized
Mar 30, 2008 03:40 AM
rx7world
Sep 4, 2007 10:55 AM
