My A3 is overheating, help.....
Old Jul 31, 2004 | 02:52 PM
humphren's Avatar
Default My A3 is overheating, help.....
I am the owner of an A3 1.8 t Sport. Its a 1998 model.
My Audi overheats when I am on the motorway, however when I am stationary it seems fine and the fans start working. The temp gauge has gone to at least 100 degress.
Can anyone suggest what might be wrong??
Old Jul 31, 2004 | 11:08 PM
ImolaS4's Avatar
Default RE: My A3 is overheating, help.....
Do you mean the cabin temp gets up to 100 degrees or the coolant temp gets up to 100 degrees or the oil temp gets up to 100 degrees?
And what do you mean the Audi overheats? Is it because you get coolant steam from the engine bay or that the gauge reads "hot"?
Old Aug 1, 2004 | 09:55 AM
humphren's Avatar
Sorry, the coolant temp get to 100 degress +. The temp warning light comes on. No coolant steam from the engine bay. Also the air con goes warm when the temp rises.
Old Aug 1, 2004 | 11:58 AM
ImolaS4's Avatar
Two things to check:
1. Thermostat.
2. Coolant sensor switch.
I'm a little perplexed that 100 degrees is considered hot, though. That sounds normal to me, but I don't know the A3 very well. It certainly is odd that it would register hot while moving and "OK" while stationary. I'm assuming you've checked for leaks and that you've checked to see that your coolant level is correct, right?
It's more than likely the thermostat; check that first.
Old Aug 1, 2004 | 12:29 PM
humphren's Avatar
Thanks for the advice. The operating temp has always been 90 degrees until now.
Old Aug 1, 2004 | 12:45 PM
ImolaS4's Avatar
Keep us posted on the progress of this humphren. It will be good to have the results posted after you get it all sorted out.
By the way, I'm going to move this thead to the A3 forum later today so that it will be properly archived.
katcoota
Mar 8, 2009 11:25 AM
Sherman Banks
Aug 9, 2008 02:07 PM
Teutonic2.7T
Jul 3, 2008 11:50 AM
pete47
Apr 10, 2007 07:44 PM
