My current issues.
Old Mar 7, 2009 | 01:08 PM
larrypzlast's Avatar
Member
Default My current issues.
Alright well my Audi kinda had an accident (2001 A4 1.8tQT 5spd) a little bit back. I have been postponing the repair because lack of funding, well the income tax came back a little earlier than I anticipated and I got alot back. I figured most of the work that needed to be done I can handle with a little help from the great minds of Audiforums! Anyway here goes.
One day I was driving down the street when this loud (and I mean loud) noise came from the front left under the bonnet. Then I shift into second and I heard a loud pop and plastic started to fall from under the vehicle. I pull over and I pull the hood release cable and nothing. It was loose had no tension. Well I limped over to a shop and they lifted the car 8 feet and opened the hood with a pry rod. After that we got it down to see what the hell happened. My fan blade and fan shroud assembly completely shattered. It took out a couple of vacuum hoses, hood cable, and my AC belt with it.
Now I am faced with a decision, I can have them replace the fan shroud, fan blade, all vacuum hoses, hood cable, and the AC belt, to the tune of about 1200 dollars, or I could do it myself!
That being said.....I need to know a place where I can pick up these parts on the internet, that would be greatly appreciated. Also if someone could point me into the right direction of a fan blade/fan shroud installation that would be awesome . I can do the AC belt, hood cable, and Vacuum Hoses without a DIY I just gotta find the parts.
All Help is appreciated .
Old Mar 7, 2009 | 09:52 PM
auditech79's Avatar
www.ecstuning.com www.purems.com www.germanpartsonline.com or if you want to save some money on the shroud you can get it used at www.shokan.com
Old Mar 7, 2009 | 11:47 PM
Member
Thanks! Do i need to replace the fan clutch as well? Do you know where I can find a DIY for the fan blade/shroud assembly?
Old Mar 8, 2009 | 11:51 PM
auditech79's Avatar
Look on audiworld on how to do a timing belt, that will show you have to remove the front service carrier which the shroud is attached to. Its a pretty easy fix, and yes you should replace the fan clutch.
Old Mar 9, 2009 | 11:22 PM
Member
Default hmmm
Alright i figured it was a good idea. 2 more things i need help on. How in the hell am I going to pop my hood lol. Also I dont think they make shrouds for the 1.8t. I found pulleys clutches blades but no shrouds. I found shrouds for the a4 v6 but not for the a4 4cyl.......
Old Mar 11, 2009 | 10:46 AM
auditech79's Avatar
Just ask shokan for a used one or get one from the dealer. I thought your mechanic already opened your hood? You will probably have to do what he did and use a long screwdriver and pop it open from the bottom.
B5 Audi
Nov 22, 2012 05:17 PM
bad34
Feb 28, 2012 12:13 PM
vincevega
Sep 9, 2009 07:38 PM
Mr. Phil
Sep 4, 2009 08:35 PM
gmund
Nov 10, 2007 07:52 PM
