Need advice on fog light buld replacment
Can anyone tell me if it complicated to replace a front fog light bulb on my 2001 A6 4.2? Owners manual implies you have to go in from the engine compartment.
Cheers.
Dan
Cheers.
Dan
It is easy from the outside. You need to remove the plastic grille first (slowly, no screw, do not damage it). Then remove the black plastic around the light (3 plastic pins) and you'll see 3 screws. After that you open the plastic cover, replace bulb (do not touch the new bulb), repace al plastics, enjoy your V8! The only thing is that the connector is a little short...
