Need Engine Overhall -New York area
Old Apr 9, 2012 | 02:25 PM
joseph08's Avatar
Default Need Engine Overhall -New York area
Hey guys new to the site. Have an '06 S4 and one of my cylinders doesn't have any compression so I need an overhall. Any suggestions of a good place to bring it to get fixed. I live in CT near New York. Thanks
Old Apr 9, 2012 | 03:16 PM
shipo's Avatar
Are you sure you need a complete engine overhaul or do you just need some cylinder head work?
Old Apr 10, 2012 | 07:52 AM
joseph08's Avatar
Default engine overhaul
Ok here is my exact situation. My low oil light has been coming on more frequently than usual so i brought it into an audi dealer. they said they did a compression test and 7 of the 8 cylinders where working correctly but #6 was totally shot and oil was leaking into the cylinder and burning there. they suggested I get a new engine but my car is an 2006 so I don't want to put a new engine on a car that old. I'm not experienced enough to know what I need, what is your opinion? And thank you very much for responding
Old Apr 10, 2012 | 09:02 AM
shipo's Avatar
First off, lose that dealer and find yourself a good German or European car repair shop.
Second; ask the new shop to make a bore scope inspection of the cylinder. This process is kind of like a colonoscopy for your car in that they stick a small camera down into the cylinder through the spark plug hole and have a look-see. From that they can tell whether the cylinder walls are all hosed up, or if the source of the oil is simply from a messed up cylinder head.
If the problem is a head, then have the head rebuilt or replaced; problem solved. That said, if the cylinder wall is hosed up, then you're looking at an engine rebuild or a replacement.
Old Apr 16, 2012 | 08:50 AM
joseph08's Avatar
Default Thank you so much
Thanks so much for your advice, it helps greatly. I did find a guy in Danbury I'm going to bring it to.
Old Apr 16, 2012 | 09:32 AM
shipo's Avatar
Cool, keep us posted on how you make out.
Old Apr 17, 2012 | 07:43 AM
joseph08's Avatar
Default there is one more twist
so i found an mechanic who used to work at an audi dealer and he told me he saw so many issues with the 4.2L V-8 that he even saw audi pick up the bill for the fix. So I called Audi Corp and I should hear back today. I will keep you posted an once again I really appreciate it.
Calvinrocker
Oct 7, 2010 02:37 AM
b5audi1.8t
Mar 13, 2009 03:19 AM
salami
Jul 26, 2007 06:06 PM
