need help i ran out of gas and wont start now
Old Mar 22, 2009 | 02:44 PM
02tt03gsxr's Avatar
Default need help i ran out of gas and wont start now
i have an 02 tt 1.8 225. i ran out of gas and refuled. it started once and ran for a min. then died it will not start again. any ideas?
Old Mar 23, 2009 | 11:56 AM
audianthony's Avatar
Ive never ran my car out of gas cause I was always afraid that the fuel pump might get clogged or suck up dirt or what evers in the bottom of the gas? so maybe your fuel pump is clogged or broke?
Old Mar 23, 2009 | 12:04 PM
nm3210's Avatar
Just try it again. That could have just been where there was air in the lines from having no gas. You should be able to just start it up a couple times (worst case, press the gas in a bit) and it will fill the lines back up with fuel. Chances are nothing else is the matter. Anybody else want to chime in?
Old Mar 23, 2009 | 05:19 PM
new_owner's Avatar
That has worked for me in the past, in different type of cars. As stated above, should do the trick...
Old Mar 23, 2009 | 05:58 PM
zippy_gg's Avatar
Wink
While you are at it I would replace the fuel filter. That is good prevention medicine, yet often neglected!
Old Mar 24, 2009 | 12:06 AM
Prizmatik's Avatar
I agree with "audianthony". You probably clogged the fuel pump. You can try to bang on the bottom of the fuel tank to shake anything loose. This actually worked for me on a 2001 Chevy Cavalier, I couldnt believe it worked. Let us know what you find out. Good Luck.
Old Mar 25, 2009 | 10:23 AM
Blind92890's Avatar
Everyone seems to ignore the obvious so I figure I'll toss in my two cents. Check your air filter first, if its clogged your engine cant breathe, then check the spark plugs, if the engine has idled so low in the rpms that it stalls out this might be a contributing factor.
I always check the simple stuff before moving on to what seems to be the direct cause personally. Half the time it can save you a lot of money.
Old Mar 31, 2009 | 12:09 AM
FloppyJunk's Avatar
Default OR....
The other obvious is that you have run your car low on gas too many times and your fuel pump has finally burned out. Just a thought, check fuel pressure.
Old Apr 23, 2009 | 12:52 AM
ImTheDevil's Avatar
Yeah, it may have vapor-locked the pump. Seems that was an issue more on older cars than ours, but it can still happen.
Old Apr 23, 2009 | 12:35 PM
Rennspeed's Avatar
I dis agree with the above pressing the gas on a fuel injected car only cuts injector pulse width and would make it harder to start hiting the bottem of the tank helps free a stuck pump moter that is on its last leg turn the key on and listen for the pump it should run for a few sec and then stop if it does repeat this step 5 times and then crank the engine w/o pressing the gas if the pump makes a load hum banging on the tank will work if no noise then yes a pump may be the cause.
