no acceleration....
Old Mar 19, 2008 | 05:36 PM
ninetythree90S's Avatar
Default no acceleration....
i have a 93 90s with the 2.8 v6. recently when i put my foot on the gas, it hesitates really badly and sometimes i have no acceleration at all. i do know that the check engine light does pop on and off once in a while but when i went to auto zone to see if they could check it they said they could not. i was thinking maybe it was the fuel filter (which auto zone also did not have!!) since it has 130k on it and is possibly the original. im not to familiar with the sensors on this car but im assuming that it could be this also. any help would be greatly appreciated.
Old Mar 27, 2008 | 02:46 AM
Audi 90Sport Quattro's Avatar
Default RE: no acceleration....
the same thing has happend to me...I replaced the plugs, ran seafoam, put some more correct plug in because they were fouled up from the seafoam, replaced the orginal fuel filter (219k on it), replaced the non functioning throttle positioning sensor(thought that was the problem),cleaned the Throttle body and then found out my #3 and #6 valves are getting blowby and loosing compression. Do a compression.
Old Mar 27, 2008 | 04:09 PM
SAudi's Avatar
your obd1 so i doubt many places can help you out, but from what ive seen with other car here with those symptoms it sound like you got misfires due to bad coilpacks. try a search on misfire codes.
Old Mar 27, 2008 | 06:17 PM
mattadams21's Avatar
hey guys it could be clogged cat converters. I have seen cats so bad where the car is sluggish and not breathing well. good luck
noir
Jul 29, 2013 11:51 PM
JayJaeMc
Jan 13, 2009 01:02 PM
alias747
Dec 9, 2006 02:11 PM
XansMom521
Feb 27, 2006 12:52 AM
Dudek12
Feb 13, 2005 09:33 PM
