No heat, only cold air blowing
Old 02-27-2017, 09:17 PM
Tony Perish's Avatar
Default No heat, only cold air blowing
Hello, I'm hoping someone here can help me out. I recently purchased a 2001 Audi A4 2.8l Quattro wagon. The only problem I seem to be having is with the heat. I turn on the heater and only get cold air blowing. The climate control works fine. i checked the inlet/outlet hoses on heater core, they're both very hot. I have no air in the system either, and i checked the fuses which checked out ok. Now is there a possibility that i have a blown relay or something else? Any input on the matter would be extremely helpful. Thank You.
Old 02-28-2017, 08:28 AM
dave944's Avatar
It sounds like the Climate Control servo that controls the flap that varies the temperature is not working correctly, or at all. However, it could also just be a dirty (clogged) cabin air temp sensor port. It is usually a small open port (looks like a tiny defroster port about an inch or so square) on the dash somewhere. Most are located on top. These can get dirty and easily blocked off. Take a vacuum cleaner and see if you can suck some air back through it. This might clean it out enough for it to start working again.
Old 02-28-2017, 11:55 AM
doroth's Avatar
Great tip Dave! I would do the same
bmwblack
Audi Q7
02-21-2013 11:13 AM
soltisb
01-24-2013 09:26 PM
Koldham
09-05-2012 12:10 PM
neilechols
07-31-2012 11:55 AM
skatehorse_01
10-28-2008 08:37 PM
Quick Reply: No heat, only cold air blowing
