No hydraulic TB tensioner??? :confused:
Old Oct 13, 2013 | 04:50 PM
Midniteoyl's Avatar
Default No hydraulic TB tensioner??? :confused:
Hey fellas.. I'm changing out my TB/water pump due to a bad water pump (well, actually a busted bolt from the last gorrilla to change it). Taking off the TB tensioner. I noticed it was directly bolted to the block. There is no hydraulic system. Just a pulley.??
Any ideas?
Why do some pics show a tensioner like this one:
http://www.happywrenching.com/audi/a...ing-parts.html
... if its just a 'tighten and go' pulley only system?? I see empty bolt holes too.. ??
Thanks.
Old Oct 13, 2013 | 05:04 PM
Midniteoyl's Avatar
A couple of pic of the situation.. before I removed the TB, and after I removed the pulley. It goes where the long bolt is..
Attached Thumbnails No hydraulic TB tensioner??? :confused:-wp_20131011_001.jpg   No hydraulic TB tensioner??? :confused:-wp_20131013_001.jpg
Old Oct 14, 2013 | 10:38 AM
Huskerbob's Avatar
The tensioner is spring loaded. You will see a pin that needs to be pulled on the new one after you get it all installed and the belt put on.
Old Oct 14, 2013 | 01:29 PM
Midniteoyl's Avatar
I already have a 'new' one.. it is just a pulley... no pin. In the link I posted, there I do not have numbers 3 and 4. They were not on the car when I took it apart.. ??
jinsojoo
Oct 30, 2012 11:22 PM
DaMoose
Sep 3, 2006 06:22 AM
jcwolfe
Mar 28, 2006 03:56 PM
PaulA4
Jan 29, 2005 10:11 AM
