Noise when shifting P to D (after I depress brake pedal)
Old Apr 14, 2008 | 11:24 PM
polancho's Avatar
Default Noise when shifting P to D (after I depress brake pedal)
I am new to the forum and this is my first post...I will appreciate any help.
I own a 2001 Audi A6 2.8 Quattro and yesterday when I got home I noticed a grinding noise after I shift to P and depressed the brakes. At first I thought that the brake pads were worn and needed replacement.
But I decided to do another test drive and noticed that the brakes don't make any noise when stopping and depressing the pedal at any time. The only time I hear this grinding noise is after I depress the brake pedal after shifting from P to D or P to R...I found a similar thread
https://www.audiforums.com/m_269343/tm.htm
...but I guess the difference is that the grinding noise comes after I depress the brake pedal and not during shifting. The car drives fine and shifts normal. Would the problem be the transmission or the brake pads? or What exactly is causing the grinding noise?
Thanks again for the help...
Old Apr 15, 2008 | 08:53 AM
CRAZYHAWK's Avatar
Default RE: Noise when shifting P to D (after I depress brake pedal)
Lightly press on the brakes from 5mph. Do you hear the noise?
Old Apr 15, 2008 | 11:48 AM
polancho's Avatar
No, I can only hear the noise (grinding or metal to metal) when I am at a complete stop, shift from P to D or P to R and after I depress the brake pedal.
AUDIFIELD
Jan 25, 2021 12:58 PM
cnegrelli
Oct 6, 2014 10:18 AM
BaronB5
Dec 5, 2012 07:29 AM
smogs1
Mar 28, 2009 05:45 PM
jinsojoo
Jul 23, 2007 10:05 AM
