Noisy A4 FSI
When I start my A4 2.0 FSI from cold there is a noise which sounds like a dull catching noise - almost diesel like. It definately comes from the engine and clears with in 1 minute. Apparently this happens alot on other FSI 's and the garage says do not worry. It is annoying and not what I expect from an Audi.</P>
Can anyone help ?</P>
Well I have just bought a new 2.0T A4 multitronic and I find it very noisy at speeds of 30-=40 mph where the auto is doing about 1300 rpm...........Audi dealer says this is normal...I cannot believe this is true........................so a saga has just started.
Any one else have this propblem
Personally i dont care for the fsi for that reason. Theyre just to noisy. I know the system can temporaly be turned off. Not sure if it can be done permanatly but that may be something youll want to look into.
ORIGINAL: dankhound
The FSI engine is always noises like a diesel and it's perfectly normal - especially when it is cold.
Theres a way to temporarily disable the fsi using the factory scan tool. Its pretty cool. Engine quites right down and everything. I was suggesting that you look into see if there is a way to permanatly disable the system and run it like a normal fuel system to get rid of the noise.
Ive only seen it done using the factory scan tool but the fsi engine can run on normal fuel pressure. Maybe a chip programmer can find a way to permanatly disable the system for the people unhappy with the noisy engine they just bought.
