Noisy A4 FSI
Old Feb 18, 2003 | 11:28 AM
Palfreen's Avatar
Default Noisy A4 FSI
When I start my A4 2.0 FSI from cold there is a noise which sounds like a dull catching noise - almost diesel like. It definately comes from the engine and clears with in 1 minute. Apparently this happens alot on other FSI 's and the garage says do not worry. It is annoying and not what I expect from an Audi.</P>
Can anyone help ?</P>
Old Oct 28, 2005 | 04:18 PM
ascotaudi's Avatar
Default RE: Noisy A4 FSI
Well I have just bought a new 2.0T A4 multitronic and I find it very noisy at speeds of 30-=40 mph where the auto is doing about 1300 rpm...........Audi dealer says this is normal...I cannot believe this is true........................so a saga has just started.
Any one else have this propblem
Old Nov 6, 2005 | 01:18 AM
dankhound's Avatar
Personally i dont care for the fsi for that reason. Theyre just to noisy. I know the system can temporaly be turned off. Not sure if it can be done permanatly but that may be something youll want to look into.
Old Nov 8, 2005 | 10:13 PM
AudiTech04's Avatar
Not sure what you mean turned off permanatly but if you did that the car would not run
You can only turn it down for service on the fuel system, at that psi the fuel would go right through your skin
Old Nov 9, 2005 | 10:19 AM
Jestnomen's Avatar
6th Gear
ORIGINAL: dankhound
Huh? What do you mean? How could you turn off FSI? All fsi is the way the fuel is injected directly into the cylinder at very high pressures.
The FSI engine is always noises like a diesel and it's perfectly normal - especially when it is cold.
Old Nov 9, 2005 | 02:39 PM
techbod's Avatar
I wonder if some one is getting mixed up with an FSE boost valve rather than FSI direct injection
Old Nov 10, 2005 | 02:14 AM
dankhound's Avatar
Theres a way to temporarily disable the fsi using the factory scan tool. Its pretty cool. Engine quites right down and everything. I was suggesting that you look into see if there is a way to permanatly disable the system and run it like a normal fuel system to get rid of the noise.
Old Nov 10, 2005 | 01:27 PM
Jestnomen's Avatar
6th Gear
What is your source? Explain please.
Old Nov 10, 2005 | 03:48 PM
techbod's Avatar
yes please tell
Old Nov 10, 2005 | 06:48 PM
dankhound's Avatar
Ive only seen it done using the factory scan tool but the fsi engine can run on normal fuel pressure. Maybe a chip programmer can find a way to permanatly disable the system for the people unhappy with the noisy engine they just bought.
