Is this normal?
Old Jun 29, 2008 | 01:20 PM
sampeck1324's Avatar
Default Is this normal?
Is it normal for my 1999 A6 2.8 to sound like the water pump is still pumping after the engine is shut down for about 2 or 3 minutes? I look at the coolant reservoir and you can even see it moving the coolant a little bit.. Is that usual?
Old Jun 29, 2008 | 07:45 PM
matasci's Avatar
Default RE: Is this normal?
is it an electric pump? cuz some of the newer cars keep the radiator fans on after shut off to keep the engine at opperating temp. and cooler. cuz normally when you shut your car off the block will get hotter. so maybe audi does it? if its belt drivin that wouldmake no sence.did you flush the system or do any work to it? some systems have to be bleed for air. that sounds like it might give the appearence of what you are seeing.
Nevalite
Apr 23, 2010 11:39 PM
sirminder
Aug 13, 2009 11:08 PM
P.O.S._for_today
Jun 4, 2009 07:21 PM
Bklynrx7
Apr 21, 2009 12:55 PM
Brandon2000s4
Jul 20, 2007 06:44 PM
