not starting, fuel pump problem
Old Jun 21, 2020 | 09:15 AM
ecoombes's Avatar
Default not starting, fuel pump problem
car wont start,
only have 4volts on supply side when ignition fired.
supplied separate 12 v to pump which primed and then it will start
leave for an hour pressure drops and wont start
does any one think, like me, this is a relay issue
or do you have any other ides.
Old Jun 27, 2020 | 07:43 AM
ecoombes's Avatar
ok all sorted:
changed fuel pump relay - still the same.
Turns out it was the crankcase position sensor - (very fiddley to change) but once changed all sorted
so the process was check fuel pump works with separate feed - yes - just lift base of rear seat and remove cover - 3 screws
replaced relay only cost a few quid so you know it is ok - yes - have to lower the dash lower drivers side to get to it
then go for the crankcase position sensor. got at from above but you have to remove quite a few bits and pieces to get to it.
bit long winded but at least gives a pattern of working and in order of difficulty to change/check
rgwilliams44
B7 Models
10
Dec 20, 2021 01:00 PM
Russ Pederson
Nov 10, 2016 09:27 PM
Michael Espiau
Sep 14, 2016 10:37 AM
johnnyg
Nov 10, 2009 04:47 PM
viyamate
Apr 5, 2008 03:13 AM
