ob5 p177500
Hello
I am automatic transmission builder. I have an Audi q5 with dl501 gearbox and i have this fault code: p177500 hydraulic pressure sensor 1 -g193 adaptation limit reached. I replaced with brand new all the clutch, i checked the mechatronic (valvebody) and put the mechatronic repair kit with brand new solenoids and harness. Then i put the latest software in the gearbox. Nothing happens the fault came back again. The car runs fine until the oil temps goes to 60 degree celsius then the fault code comes again only in the scan tool not with MIL light. If you push the car beyond 85 celsius sometimes has 2-1 harsh and D harsh engagement. Anyone knows what this fault code is and how can i solve this. Also i take the tcm to a local ecu specialist to check the pressure sensors and he told me that they havent problem. Anyone can help? Thank you!
I have Audi 7 2013.. transmission working absolutely fine just I’m getting error Gear is overheating change driving style .. and fault code is P1765 hydraulic sensor 2 ( G194) adaptation limit reached .. pls advise what could be the actual problem??
mooseposse
Apr 28, 2020 06:42 PM
