Odd noises
Old Mar 31, 2007 | 01:49 AM
CLX's Avatar
CLX
Zombie Defense Force
Default Odd noises
All right, I've got my 99 A4TQM with a few odd noises. The first seems to have been cured, it was making an almost indescribable, yet very quiet sort of whirring noise until the oil temp came up. I changed the oil with Penzoil full synthetic and a Purolator filter and viola, no more noises. But the second noise is still there. It sounds much like a squeaky brake coming from the front left wheel. It doesn't seem to change in intensity or volume with vehicle speed, and it's not the engine because it isn't dependent on engine speed (shut the car off while rolling down a hill to be sure.) It's almost inaudible, but it is definately there. Any ideas? I am about 100% sure it's not like, a loose brake pad or anything because it passed it's MA state inspection only a few days ago and the brakes are one thing they check. I'm stumped, because I've taken the wheel off and visually inspected it, finding nothing.
Old Apr 1, 2007 | 03:17 AM
Vaudi's Avatar
Default RE: Odd noises
Sometimes aftermarket brake pads make noise. Also if the rotors werent changed with the new pads they sometimes make noise.
Old Apr 1, 2007 | 03:23 AM
AWDaholic's Avatar
Senior Administrator
You're 100% sure all the brake parts are where they're supposed to be? I had a similiar sound coming from my r/r axle shortly after purchasing mine, turned out to be a slipped pad was ever-so-slightly wearing against the side of the rotor hat. Pulled the wheel, cudn't find anythuing obvious... Pad "looked" OK. Dint think to check it from a different angle. Eventually it wore through enough that when I hit the brakes it SNAPPED the rotor off of the hat (a 1-piece casting, on stock rotors).
double check, to make SURE, fore your own sake.
Old Apr 1, 2007 | 09:18 AM
CLX's Avatar
CLX
Well, I like taking things apart so, I'll be doing that today to check everything out. Thanks!
Old Apr 4, 2007 | 10:56 PM
SAudi's Avatar
if its a whirring noise im pretty sure its the wheel bearing going, try this jack up the side that you hear it from and try and jiggle the wheel, if you get any play its definetly your wheel bearing.
salleuxe
Nov 11, 2009 05:33 PM
drogce
Aug 15, 2009 01:12 PM
QuickQuattro
Apr 30, 2007 09:19 PM
rowlandc
Jul 7, 2006 12:23 PM
ssss
Aug 2, 2005 09:04 PM
