Oil Blow By Trouble
Old Mar 27, 2008 | 02:25 AM
Audi 90Sport Quattro's Avatar
Default Oil Blow By Trouble
How hard is it change the valve seals in a 2.8 V6 12v?
Sorry double post...How do I delete this post?
Old Mar 27, 2008 | 04:44 AM
techbod's Avatar
Default RE: Oil Blow By Trouble
its a full head strip down if you dont have a pressure pump to hold the valves up while you remove the valve springs to get to the seals and then you need the tool to compress the valve springs while the head is in place, a lot of work[:@].
edit: worth a read
http://en.wikipedia.org/wiki/Audi_A4
Old Mar 27, 2008 | 01:49 PM
I have a friend that has a air compressor and has some knowledge but I cant find a write up for how its done. Can you post a little write on it for how it is to be done? I called around and I was told by a Audi/VW well known shop in my area and the worst case senario was about $400 for head to removed and about $140 for the what you talked about but, I would like to do this with some help so I can learn something new and feel better about it plus save some money. Thanks again.
Old Mar 27, 2008 | 09:32 PM
tHe kNiGHt FaLL's Avatar
its not a begginers task i would recommend for someone...
Old Mar 28, 2008 | 11:34 AM
I figured so...just made a appt. to get it worked on at a very good shop.
blackedoutaudi
12
Mar 23, 2010 11:46 AM
Mar 27, 2008 02:23 AM
1.8TK3MP
Feb 14, 2008 08:24 PM
theguy1084
Nov 20, 2006 03:04 AM
Bantanic
May 18, 2006 04:23 PM
