p0432 catalytic converter / aftermarket replacement?
Old Oct 21, 2008 | 09:24 PM
audi-up's Avatar
Default p0432 catalytic converter / aftermarket replacement?
Hello. I have a 98 a4q 2.8 30v, it has 180k. I got a cel and it is the p0432. If I clear it it comes back in a couple hundred miles. Does anyone have experience with the Magnaflow or Monster Flo? Can I just gut it? Will the cel stay off? I live in PA and we have emissions testing. I worked at a VW shop in the late 80's and I remember the boss putting a gti up on the lift and running it hard while slamming the cat with a hammer. The ceramic was all over the floor.
Which side of the car is bank 2?
How does the 02 sensor pick-up (if it does) the cat problem if it is upstream?
I read the audiforums archives but still have questions.
Any information would be helpful. Thanks.
Old Oct 22, 2008 | 05:26 PM
Darkprodo's Avatar
no you can't gut it.
you can go aftermarket, but they have to be Audi specs replacements. i've had to replace new aftermarket cats cause they MIL keeps coming back on.
bank 2 is the left side if your sitting in the car.
and you have two o2 sensors per bank. they compare readings. the second o2 has to read lower but a certain amount or the Cat Efficiency code is set
Old Oct 23, 2008 | 01:41 PM
audi-up's Avatar
I only see one 02 sensor on each side in front of the cats? Schematic from Bentley a4 manual. Thanks.
Old Oct 23, 2008 | 05:21 PM
Darkprodo's Avatar
G39, G108, G131, and G130
4 oxygen sensors.
Old Oct 23, 2008 | 07:41 PM
audi-up's Avatar
Sorry, I'm slow. Thanks for response.
I see G130 and G131 are the 02 sensors before the cats, one on each side. There must be two behind the cats that aren't shown. I see in the fuel / ign. section that there are two sensors per bank. thanks.
Old Oct 25, 2008 | 02:41 PM
mr_synister's Avatar
ya there is sensors up the wazoo on these cars its hard to to a custom exaust on them without realllllly knowin what your doin.
ballardnaomi1
Oct 11, 2013 07:22 AM
haggardtrish
Apr 23, 2011 07:18 PM
btmlinedan
Jan 3, 2011 01:45 PM
tistheoc
Jun 15, 2010 06:54 PM
DLD33
Mar 23, 2010 04:54 PM
