Please HELP !!! ENGINE MISFIRING
Old Dec 27, 2005 | 07:40 PM
twinblowersonice's Avatar
Default Please HELP !!! ENGINE MISFIRING
I got my turbo A6 couple of weeks ago and the check engine lights was on. I checked it out on OBD and it was a "random cylinder misfire". I reset the code and my mech supported my theory of "if it aint broke don't fix it". B U T !!! The light came back on !!! So now I wanna fix this problem. PLEASE help me : what could this be? AND Where should I get the parts?
THANX FOR ALL YOUR HELP,
Old Dec 27, 2005 | 07:46 PM
BaconBait's Avatar
Default RE: Please HELP !!! ENGINE MISFIRING
Do you have the fault code? There's a couple guys running around here that can pinpoint the problem.
Old Dec 28, 2005 | 01:53 AM
I don't have the code, but I will post i in two days - my guy's on vacation Also, I noticed that the engine compartment smells of burning oil when I drive fast and when I start the car up... Could it be a coil?
Old Jun 21, 2006 | 07:05 PM
crashnburn's Avatar
Yes, or your running to rich on startup causing blowby !
Crashnburn
Old Jun 21, 2006 | 07:09 PM
techbod's Avatar
fault code please, the oil smell is probably a leak from the cam cover onto the exhaust manifold
Old Jun 21, 2006 | 07:12 PM
techbod's Avatar
ps it could be the reason for the fault (oil build up round the spark plug causing it to short out) a common fault associated with rocker/cam cover fail
Old Jun 25, 2006 | 01:54 PM
dankhound's Avatar
When does it misfire? If its at cold start theres a bullitin about that. You replace the injectors and the thermostat.
Old Jun 26, 2006 | 09:45 AM
I can't feel the engine misfiring. The only reason I think that's the case is because when I hooked it up to the OBD, it told me "random cylinder misfire" as the reason for the check engine light coming on.
Coincidentally, I've been told that it may be as simple as the the module that regulates the air/fuel mixture being bad. I am planning on running some in-depth diagnostics on the car soon, so I will know it all in great detail soon as that happens.
Old Jun 26, 2006 | 09:52 AM
one thing I've figured out for myself for a fact is that most mechanics have no clue what to do when it comes to these cars. Luckily, I have a friend who happens to be a used car dealer and a former mechanic himself - if not for him, I would have spent at least a 1000 bucks on this unnecessarily by now. In the meantime, the car is running just fine and the only indicator of any problems lurking on the horizon is the fact that I will probably have to replace the timing belt soon - just because of the mileage and my unwillingness to buy a new motor :-)) I also get occasional burnt oil smell from under the hood and the check engine light is on - other than that, B E A UTIFUL :-))
Old Jun 29, 2006 | 11:04 PM
dankhound's Avatar
Since the car isnt constantly misfiring we can probably rule out injectors, coil, plugs, and ignition module. One posiblility is that carbon buildup is causing the ocasional misfire on a random cyclinder, another is as you stated a faulty ecm. Also dont overlook a failure somewhere with the engine speed sensor and the flywheel. Never seen something like that but keep in mind the ecm uses the acceleration and decelleration it reciveves from the engine speed sensor to decide wheter the engine is misfiring or not.
Tjozza
Jul 5, 2015 07:08 PM
mtizzle981
Nov 25, 2013 10:43 PM
drewsaudi
Oct 4, 2011 01:21 PM
Inibalir
Mar 28, 2008 10:27 PM
fmedina22
Feb 15, 2008 02:32 PM
