Power Steering fluid in fuel tank
Old Oct 2, 2005 | 05:29 PM
Euge82's Avatar
Default Power Steering fluid in fuel tank
Ooops. I poured about 6 ounces of STP power steering fluid into my gas tank. I thought it was fuel additive. What should I do? If I run it through the fuel system will it damage anything? I own a 1998 A6, 2.8 with 100,000 miles. The tank is full and holds 18 gallons of gas or in my case 6 ounces of power steering fluid.
Thanks
Old Oct 3, 2005 | 05:52 AM
flyboy's Avatar
Default RE: Power Steering fluid in fuel tank
It may foul your spark plugs but worse yet it may fry your cat. I don't know what to tell you.
Old Oct 3, 2005 | 10:44 PM
Euge82's Avatar
This quick reply came from the fine folks at STP.
According to my technician you should not have any problems. You would want to keep topping off your gas tank to dilute it more. It would also be recommended to do some highway driving to help burn it off. It is a petro chemical compound and should burn off. It may cause a little soot around the sensors and it might cause the check engine soon light to come on because of it. He said as long as you keep diluting it you should have no troubles.
Old Oct 3, 2005 | 11:03 PM
flyboy's Avatar
hope your right, I know that a little oil in the exhaust can burn up the cats but good luck. Oh and get that in writing from them. you know just incase.
Old Oct 4, 2005 | 12:12 PM
CRAZYHAWK's Avatar
That power steering fluid should not be used in the power steering for an Audi.
Old Oct 6, 2005 | 04:03 AM
russianari's Avatar
not to be an ***, but you should probably learn to read.....
02A4kid
Nov 15, 2010 04:41 PM
tculber
May 28, 2008 09:36 AM
TheModernAge
Nov 14, 2007 09:53 AM
thrax982
Mar 31, 2005 10:15 PM
