rear defrost/ radio reception....
Old Feb 7, 2006 | 03:25 PM
pete7's Avatar
Default rear defrost/ radio reception....
i have a 97 a4 2.8Q. my rear defrost doesnt work and i also have crappy radio reception on the stock head unit. when i hit the rear defrost button, the light on the switch comes on but its yellow, when all my other switch lights are green when they are turned on. (dont know if that matters or not). well i took off the rear trim panel on the drivers side to check for voltage for the rear defrost and i found a little green colored, rectangular shapped box about the size of a cellular phone. it has one wire going into it and a coax cable going into it. i figured the cable going into it is for the radio antennae. well i got 12 volts on the input wire when i turned on the defrost button so i know its getting power. it has 2 wires coming out of it that attach to a strip on the window (heating element i'm assuming), 1 power and 1 ground wire. the power wire has constant voltage on it whether i hit the defrost button or not and the ground wire was broken. well i thought this was the problem, so i put on an electrical connector and attached it to a little lip type thing on the heating strip cause i assumed thats where it came from. well it still doesnt work. so i have a couple of questions. 1) is the cable going into the box the radio antennae? and if it is, then why would i get 12 volts on the wire when i turn on the rear defrost? and 2) am i missing something for the rear defrost? i mean, i inspected the elements and they look perfect. i couldnt find a break in the element anywhere so i dont think thats the problem. so am i looking at the right thing? is the heating element on the drivers side or the passenger side? or can the heating elements itself go bad? or did i connect the ground wire to the wrong spot? should i have just grounded it to the chasis somewhere? any help with this would be great.
Old Feb 10, 2006 | 01:19 PM
pete7's Avatar
Default RE: rear defrost/ radio reception....
well since nobody has posted to help me, i'll go ahead and tell whats wrong with it. i found a broken ground wire to the rear defrost. its located on the passenger side rear window panel. but while i was tearing thins aparts, i fixed the broken ground wire for my radio antennae signal booster and now that is working again as well.
Old Feb 11, 2006 | 04:21 PM
avanttripleloop's Avatar
thanks for the post and answer.if being a multiple use ground,was there a difference in stereo reception?
Old Feb 11, 2006 | 04:31 PM
techbod's Avatar
covered and hopefully sorted via email
jabjab
Sep 22, 2014 07:52 PM
jbrochu
Jun 17, 2012 12:37 PM
wand106
May 8, 2008 03:59 AM
mmenta
Oct 3, 2007 07:37 PM
pete7
Feb 6, 2006 08:32 PM
