Rear Disc Brakes
Old Mar 24, 2008 | 08:34 PM
AudimaniaA4's Avatar
Default Rear Disc Brakes
I drive a 98' Audi A4 Quattro 2.8. I am planning on replacing my rear brake discs soon. I believe that the right size is 245mm x 10mm although I am also receiving 288mm x 25mm discs from search results. Would any of the two sizes fit or does it have to be one size.
I am also looking to get some performance discs. Do you know of any good performance brakes that you are satisfied with? I am also planning on doing the brakes myself, never done so in the past so any suggestions would be great.
[align=center][/align]
Old Mar 24, 2008 | 09:58 PM
tHe kNiGHt FaLL's Avatar
Default RE: Rear Disc Brakes
15mm thicker disc is a big difference... w/ new pads the caliper might not fit
Old Mar 24, 2008 | 11:16 PM
Thanks, I just checked and there was not much room to play. Well, I should get the 9.6" x .4" Any advice on which brand of disc brakes?
Old Mar 25, 2008 | 05:00 PM
PRican1.8T's Avatar
i think it'll all depend on how much you wanna pay. you can get some nice discs for well over $100 each, or you can get some cheap but normal. alldepends on what you want
Old Mar 25, 2008 | 09:07 PM
KarenCaren's Avatar
I been using DBA Brakes or EBC Brakes. Never had problems with them.
Old Mar 26, 2008 | 10:19 AM
beefski's Avatar
Unless you are doing some heavy duty driving OEM would be fine. I suggest a very cost effective break upgrade, stainless steel break lines front & back. For about $100, you can get thses lines and the breaking will be noticeably better. Paragon Performance in CA, has them. I got them for my 96 a6 avant and it stops like a champ, dead straight with a rock hard pedal. I would also suggest a compleat break fluid replacement, use the search function, I did a diy for a full break fluid replacement.
Also, you will need the special tool to re set the pistons in the rear calipers
83coupegt
Jan 6, 2014 10:07 PM
rustlerboi1052
Jun 1, 2009 09:41 PM
AudimaniaA4
Mar 23, 2008 08:14 PM
jazzyman
Sep 27, 2007 09:23 AM
eskloe
Dec 3, 2006 02:15 PM
