replace brake pads now rattle
I just recently replaced the front brake pads and now there is a rattle only when I hit bumps / potholes. Braking is smooth with no noise. I doubled checked everything to make sure they were snug. Any thoughts?
RE: replace brake pads now rattle
still no reply to this? ive been hoping someone can answer this b/c i've had this problem for almost 2 years. even w/ oem brakes. the dealership says there's nothing they can do. not sure if theyre just being lazy or if they're telling the truth. any help guys?
You might have a problem with your control arm bushings.
https://www.audiforums.com/m_37829/tm.htm
Audi had a recall on them. I don't know what years exactly though.
I had this problem and FIXED it. Everyone told me it was control arm bushings, but that made no sense, b/c it happened when I swapped out brakes. My problem? Piece of garbage pads. I talked to alot of other Audi guys about this and even a few guys over at Renn-Art, and they said you need to use Mintex pads. They are amazing quality. Since I've swapped out the fronts and rears last week with the Mintex, BOO YAH... no rattle. Just look into some better quality pads.
Why don't you take the wheel off, put the arm on another jack and raise it up and down. Listen to the noise and hopefully you will find the problem. I had the same noise but only at the back, it used to drive me crazy trying to find out where the noise is coming from. I jacked up the wheel axle up and down and found the problem to be a loose bolt connecting the sway bar to the axle.
OOOOA430
10-18-2007 12:21 PM
