replacing wheel bearing?
the fronts are a bit!h. either way you really need a press, for the rears their a bit easier. first time i just took the car to a shop and got the whoel thing done for 200. the second time i had to change a bearing i just took off the upright and took it the same shop paid 50 for the bearing and 25 to have it pressed. and about 2 hours removing and reinstalling the upright. more info can be found at audidiy.com
i do work at a place that has a lil' shop, and we do have a press, so i dont think that will be a prob. any good place online to get step-by-step instructions on how to get the wheel bearing out?
http://www.audiworld.com/tech/wheel33.shtml
this is basically what i used. the most important thing with this is be careful and make sure you can do it. also be careful withthe abs sensor, i was neglegent and managed to break the sensor itself and then spent drving around 6 months without ABS ( not that i needed it, but). hope this helps
b5quattro
Sep 15, 2011 02:02 PM
xqwizit
Jun 8, 2009 01:27 PM
FACT
Oct 6, 2007 04:54 AM
