S3 over boosting!
S3 over boosting!
Can anyone offer advise on the following:
I have a 2002 Audi S3 ,it has been remapped to 270 BHP approximately 12 months ago. Recently the turbo feels like it is over boosting aswell ascausing the traction control light to illuminate perminantly . After a diagnostic check it showed air mass flow meter and turbo max boost exceeded. I have replaced the air massflow meter and the wastegate. The traction light does not illuminate now but it is still over boosting. Is it likey to be the turbo itself??
RE: S3 over boosting!
you may have over boosted in the past and it was never reset, disconect the battery cable for a few min (get the radio code first), and see if it clears it up, i read that if it happens in the a4 it has to be re-set before the code will go away.
i'm thinking your ECM tuning and i'm almost positive did NOT and can NOT overwrite the fault memory protocol.
so w/ that said. your ECM is designed throw a code say if you boost over 9 psi. your turbo is capable of more and you tune most likely allows that to happen.
to correct this situation a boost controller will be necessary. i recommend electric over manual so you can actually keep an eye on what your currently boosting
ORIGINAL: awwdii
Do you have a MBC?
Do you have a MBC?
Air fuel mixture has been checked and is ok. If the problem is ecu / tune related i can't understand why it has just started happenin now as i have had the car remapped/chipped twelve months ago and have had no problems before?
