s4 starting problems
Old Apr 4, 2009 | 10:54 PM
gaspam's Avatar
Default s4 starting problems
hi, i am new to the forum and have a question. My 00 s4 is having problems starting after its been sitting for a while- it will crank and crank and crank and finally start and then if is shut her down and restart it will start right up... same thing if i go to the store or something and arent in there long, i will come out and it will fire right up...
Does this sounds like a starter or fuel filter/ pump problem or is it something else?
Also i am stage 2+ APR but i dont think that should matter right?
thanks in advance!
Old Apr 5, 2009 | 10:06 PM
matasci's Avatar
try checking you cam signal. if the cam sensor is done. the computer has to find the cylender order through the crank sensor which takes longer, causing the long start.
Old Apr 6, 2009 | 10:23 AM
gaspam's Avatar
how do i do that? sorry, new to s4 and dont have manual yet or vag com but getting it soon
Old Apr 7, 2009 | 01:55 AM
Isramirez21's Avatar
Do you have a check engine light?
When was the timing belt done?
Check for Crankshaft sensors, but You should scan it first and post the codes here.
Old Apr 7, 2009 | 10:17 AM
gaspam's Avatar
well i just bought the car and was told timinig/ water pump was done at 90K and it has 107K now... check engine light was on- for catalytic converter code- cleared it, no other codes.... the cat one came back - i have apr full exhaust so i assume cat code will always be coming back?
Old Apr 9, 2009 | 11:48 PM
matasci's Avatar
to check you signal on your cam you need a digital multi meter. im not too fimiliar with the s4 motor but the sensor should be very near the cam where ever you number one cyl is. just check to see if there is voltage.
also what you originally posted about fuel filter or pump problem is a possibility. i would change the filter regaurdless and see if it fixes it.
if this just started its probably not going to be a timing issue. go from there and repost results.
if the exhaust is street legal it should not be throwing cat codes. and you should find the issue with that as well.
good luck
Smokin Tubes
Feb 5, 2012 10:11 AM
joe4123
Sep 16, 2009 11:17 PM
joe4123
Jun 19, 2009 08:05 PM
james0013
Sep 2, 2008 11:22 AM
Limmy711
Sep 15, 2005 02:11 AM
