s4 starting problems
Old 04-04-2009, 10:54 PM
gaspam's Avatar
Default s4 starting problems
hi, i am new to the forum and have a question. My 00 s4 is having problems starting after its been sitting for a while- it will crank and crank and crank and finally start and then if is shut her down and restart it will start right up... same thing if i go to the store or something and arent in there long, i will come out and it will fire right up...
Does this sounds like a starter or fuel filter/ pump problem or is it something else?
Also i am stage 2+ APR but i dont think that should matter right?
thanks in advance!
Old 04-05-2009, 10:06 PM
matasci's Avatar
try checking you cam signal. if the cam sensor is done. the computer has to find the cylender order through the crank sensor which takes longer, causing the long start.
Old 04-06-2009, 10:23 AM
gaspam's Avatar
how do i do that? sorry, new to s4 and dont have manual yet or vag com but getting it soon
Old 04-07-2009, 01:55 AM
Isramirez21's Avatar
Do you have a check engine light?
When was the timing belt done?
Check for Crankshaft sensors, but You should scan it first and post the codes here.
Old 04-07-2009, 10:17 AM
gaspam's Avatar
well i just bought the car and was told timinig/ water pump was done at 90K and it has 107K now... check engine light was on- for catalytic converter code- cleared it, no other codes.... the cat one came back - i have apr full exhaust so i assume cat code will always be coming back?
Old 04-09-2009, 11:48 PM
matasci's Avatar
to check you signal on your cam you need a digital multi meter. im not too fimiliar with the s4 motor but the sensor should be very near the cam where ever you number one cyl is. just check to see if there is voltage.
also what you originally posted about fuel filter or pump problem is a possibility. i would change the filter regaurdless and see if it fixes it.
if this just started its probably not going to be a timing issue. go from there and repost results.
if the exhaust is street legal it should not be throwing cat codes. and you should find the issue with that as well.
good luck
Smokin Tubes
02-05-2012 10:11 AM
joe4123
09-16-2009 11:17 PM
joe4123
06-19-2009 08:05 PM
james0013
09-02-2008 11:22 AM
Limmy711
09-15-2005 02:11 AM
Quick Reply: s4 starting problems
