speed sensor or ABS modulator?
Old Mar 20, 2008 | 10:55 PM
PRican1.8T's Avatar
Default speed sensor or ABS modulator?
is speed sensor the same as an ABS modulator? my ABS modulator is screwed up and i wanted to get it fixed. also, how do i know which one is screwed up?
Old Mar 21, 2008 | 03:09 PM
CRAZYHAWK's Avatar
Default RE: speed sensor or ABS modulator?
Sounds like one of the ABS senors has broken down if you have access to VAG this can be tested. Go into
brakes 03
Read measured value blocks 08
001
this will display the readouts of the ABS sensors for all four wheels, then just drive the car while monitoring the read outs and see if any are diffrent to the rest. If so the ABS sensor requires replacment.
Old Mar 21, 2008 | 04:32 PM
PRican1.8T's Avatar
well i know the ABS modulator is messed up. i have the diagnostics from audi, but i was just wondering if the ABS modulator and the speed sensor were the same thing because if they are, it'd be cheaper for me to buy those, but i just need to know. thanks!
Old Mar 22, 2008 | 09:37 AM
CRAZYHAWK's Avatar
The ABS computer is not the ABS wheel sensor.
Old Mar 23, 2008 | 12:50 AM
PRican1.8T's Avatar
okay, thanks
Old Mar 23, 2008 | 02:39 PM
aiden11's Avatar
The abs modulator is located under the hood on the drivers side.. the speed sensors are at each wheel.. the modulator is fairly expensive to buy new.. you might want to try to find a good used one!
bobbyenglish61
Aug 27, 2013 07:55 AM
Toms Ķiris
Sep 11, 2012 06:52 AM
slimty360
Jul 23, 2010 11:18 PM
neomaxddr
Apr 1, 2009 03:16 AM
