Speedo error
Old Sep 28, 2007 | 10:51 PM
jimf's Avatar
Default Speedo error
I have an A4 softtop with 235/45 tires. I've been noticing that the speedo reads about 6-7% higher than the actual speed. Is there a way to change the speedo's calibration? It seems to be set for a 55 or 60 aspect ratio tire?
Old Sep 29, 2007 | 12:41 AM
2000Sforce.dtwaudi's Avatar
Default RE: Speedo error
No way to change. There are wheel speed sensors that are set to oem tire size. Check the "miata tire calc" (google) to see the size and rolling diameter difference.
Old Sep 29, 2007 | 06:34 PM
jimf's Avatar
That's just it. I believe a standard A4 sedan has a 60 or 65 aspect ratio tire OEM. My A4 cabriolet has a 45 OEM aspect ratio. If there is a sensor in there could it be the wrong one? Can it be replaced? Miata tire calc is what got me to thinking that the speedo isn't set for the right aspect ratio.
Thanks
Jim F.
Old Sep 30, 2007 | 01:11 AM
no it is just a photoelectric or magnetic and the ecu converts it. What makes you think your speedo is off?
Old Oct 1, 2007 | 10:49 AM
aberfitch82's Avatar
it could be the speed sensor i just kinda had the same problem except mine just stopped workin and we replaced the sensor n she works good now hook it up to the obd and see if she throws a code
DCAV8R
Jan 23, 2023 06:33 AM
vtraudt
Mar 30, 2010 09:14 PM
ilovelagar
Oct 22, 2008 12:37 PM
aberfitch82
Nov 21, 2007 10:20 AM
DUBPORT
Aug 2, 2007 03:38 PM
