This is strange
Old Feb 13, 2008 | 02:27 PM
PimpinA4's Avatar
Default This is strange
Ok Irecently purchasedan 02 audi a4 1.8t andI thought everythoing was looking good tilI noticed that my fog lights wouldnt turn on when my headlights were turned on in either low or high beam, so i figured to check the fuse box to see if the fuse was blown and heres the strange thing where the fuse should be in the fusepanel (number 19ifI remember right)there was nothing, no fusenot even metal contacts for the fuse to connect toin the fuse panel, has anyone else seen this or know why i would have fog lights that are not connected to the fuse box? and how to turn them on?
Old Feb 13, 2008 | 08:03 PM
KevinV10's Avatar
Default RE: This is strange
give me your vin and ill check out the spot it should be, maybe you mis read it, or it was mis labled.. ill verify it for you
... oh, check to see if there are bulbs and wires leaving the lights.. basically make sure its not just lenses for apearence reasons..
Old Feb 13, 2008 | 09:51 PM
dankhound's Avatar
If theres no contacts there than id be willing to bet that there isurnt supposed to be a fuse. The labels are generic and dont apply to all cars. Did you turn the headlights on and pull the headlight switch out? Thats what turns the fogs on. Also dont overlook the posiblitly of two bad bulbs.
Old Feb 14, 2008 | 06:16 PM
PimpinA4's Avatar
Hey guys thanks for the help i took it back to the dealership and you guys were correct it was mislabeled and both the bulbs were burnt out. The dealership put in new bulbs and they work just fine but it was definately strange, anyways thanks again!
bikerbob951
Feb 12, 2009 11:39 PM
vc1492a
Apr 1, 2008 04:19 PM
onepoint8tee
Aug 7, 2006 01:50 PM
elvis12
Jun 1, 2006 09:28 PM
