BROKEN OIL TEMP SENSOR
Old Feb 13, 2008 | 10:42 PM
NewJ_A4's Avatar
Member
Default BROKEN OIL TEMP SENSOR
My oil temperature gauge doesnt budge. Do i have a bad gauge or do i have a bad sensor somewhere? PLEASE HELP
Old Feb 13, 2008 | 10:44 PM
dankhound's Avatar
Default RE: BROKEN OIL TEMP SENSOR
Probably a bad sensor.
Old Feb 13, 2008 | 11:47 PM
NewJ_A4's Avatar
Member
do you know if that is an easy DIY fix or is it something i should bring to the dealer
Old Feb 14, 2008 | 02:40 AM
auditech79's Avatar
It depends, some engines have the oil level sensor and oil temp integrated into the same sensor. This would be easy to change because its bolted to the oil pan which is just a couple of bolts. Some sensors are mounted to the oil cooler ect which isn't easy to change. Check with the dealer parts dept. with your VIN number to see what you have.
Old Feb 14, 2008 | 11:12 PM
KevinV10's Avatar
auditech79 that quote at the bottom of your posts.. did a mercedes owner really ask you that? thats hilarious. is there more to that story?
ultimate_audi_77
Sep 29, 2012 08:11 PM
Scaryfatkid
Nov 12, 2010 05:26 PM
toboater
Oct 26, 2010 12:15 PM
