Strange things afoot after coolant flush
I was experiencing some smoke from the exhaust at full throttle on my 92 100 CS. After some maintenance I'm experiencing rough idle and the brakes are suddenly non-existent.
Ok, here is what I did. I did a poor-man's coolant flush by draining the coolant from the lowest hose then added fresh coolant. I opened the coolant bleeder valve and ran the car with the heat on. I can't seem to get the coolant into the system though. No air came from the bleeder valve. Yes, I know that this didn't really drain all the coolant. That isn't the issue.
I also checked the plugs for any issues. None to be seen.
Now, the idle is rough and the brakes are functioning at about 25%. The dash readout says "Brake Light".
I don't see how any of this could have affected the braking system or caused the idle to go wonky like that.
Any ideas?
Any ideas?
greyghost
Mar 28, 2006 02:58 PM
