Too high voltage - Audi A6, 2001
Old Aug 26, 2011 | 12:16 PM
stamso's Avatar
Default Too high voltage - Audi A6, 2001
Hi,
I am having a problem with a recently bought Audi A6.
1. Year of car - 2001
2. Model of car - A6
3. What engine & TIP or 6sp - 1.8 Turbo 6-Speed Automatic
4. Miles - 260 000 km
5. FWD or Quattro - FWD
6. Any CELs or stored codes -??
The voltmeter on the car is not around 14 volts as I think it is supposed to be. Instead it is all the way at max, and even beyond that. 16 volts +. After driving a little while the warning light for the enigine electronics came on.
I tried using another car battery, which made the warning light go away, but the voltmeter still said 16 volts+. I guess if I keep driving it will come back on, so I am not driving the car now.
Has anyone had the same problem? Could it be the alternator, or perhaps the voltage regulator?
I am ordering a "OBD II VW AUDI Auto Scanner OBD 2 Auto Code Reader G" from eBay to see if it'll help me somehow.
Any help is greatly appreciated! Thanks
Old Aug 26, 2011 | 07:04 PM
02A6Beau's Avatar
I'm guessing voltage regulator. the voltage regulator is a part of the alternator. if you take the alternator out you can probably have it rebuilt for a reasonable price. good luck
Old Aug 27, 2011 | 04:36 AM
stamso's Avatar
Thank you for helping out!
Isn't it weird that the warning light for the alternator doesn't come on, if that's where the problem is?
Anyways, I will post an update on the situation when I get the diagnostic tool!
Old Sep 10, 2011 | 11:51 AM
stamso's Avatar
I have measured the voltage when the car is running and when it isn't. It is exactly the same as on a different car I measured. Which probably means it's only the voltmeter on the car that shows wrong voltage.
Does anyone know how to calibrate the voltmeter on the car? Where is the sensor?
Old Sep 17, 2011 | 07:26 AM
stamso's Avatar
I don't really understand your reply... Can you explain it a bit?
The codes I got were:
16804 - P0420 Catalyst System: Bank 1: Efficiency Below Threshold
18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
17887-35-10 P1479-35-10 Brake boost Vacuum system mechanical failure.
Old Sep 19, 2011 | 02:04 PM
stamso's Avatar
I erased the codes and took the car for a drive.
Only one of them came back on.
Which doesn't seem to have anything to do with the voltage...
Any ideas?
Old Sep 19, 2011 | 05:07 PM
02A6Beau's Avatar
P0420
intake problem (leak downstream from the MAF/MAF problem)
exhaust leak
02 sensor issue
bad cat (unlikely)
good luck
Old Jul 16, 2012 | 06:39 AM
JCAN's Avatar
Hello all nice people,
Any idea what is the part number for the voltage regulator? Audi model same as Stamso's, year 2003 A6, 1.8T.
Old Jul 16, 2012 | 06:42 AM
JCAN's Avatar
Hi All,
My Audi A6 has done 180,000 km now, should I change the timing belt now? It was changed once at 80,oookm. Why can't the genuines around build cars that do not require timing belt change?
JCAN
Old Nov 16, 2014 | 07:09 AM
jhmarais1976's Avatar
Hi. I have a 2002 a6 c5 2.0 petrol that has an issue with the keys not syncing with the car both keys have new batteries. Also an issue with voltmeter reading past 16v but battery and alternator tested and ok. Water temp gauge also sits at 110 degrees sometimes 120 but when cold and ignition turned on, its already at around 60-80 degrees. what is the cause of this? cheers
Patrick1457
Mar 26, 2015 11:56 AM
Grease Monkey A4
Nov 26, 2011 03:14 PM
sukisuru
Feb 11, 2011 01:53 PM
Lovnangel1
Sep 12, 2007 12:10 PM
ravage
Aug 1, 2006 08:31 PM
