VAG COM vs. OBD tool
Old Sep 26, 2007 | 05:53 PM
IDUA ORTTAUQ 6A's Avatar
Default VAG COM vs. OBD tool
I see that a Vag Com runs $600 to $900! I also see a OBD toolfor $71..............Question, is it worth it to buy the OBD, will it diagnose most issues enough to be worth purchasing, or will I end up needing to connect a Vag Com anyway?
Old Sep 26, 2007 | 06:05 PM
tahoehtp's Avatar
Default RE: VAG COM vs. OBD tool
I think benefit of having vag-com is that you can get more details from your ECM.
OBDII is just simple diagnostic tool that read off from ECM but only reads error codes.
vag-com is way to go I think. I got both.
Old Sep 26, 2007 | 08:03 PM
2k S4's Avatar
Go here http://www.ross-tech.com/ & read, if it has thing you want, or will need, then you got to buy it, Oh, it's only $250.
Old Sep 27, 2007 | 03:32 PM
CRAZYHAWK's Avatar
Old Sep 27, 2007 | 04:57 PM
In that Ebay ad there are several meters and the one that looks more impressive is the Max Scan VAG405,Buy it Now...$149.97
How does this compare with the Vag-Com... non-professional, selling for$229. ?? Hay, there's an $80 difference, and I'm not rich!
Old Oct 1, 2007 | 08:35 AM
CRAZYHAWK's Avatar
Do you need CAN bus?
If not, buy a code reader from alpha-bid
for under $30.
bshusted
Jul 31, 2013 08:46 PM
desertsnake1991
Dec 11, 2012 07:00 PM
ericcota2003
Apr 2, 2010 10:44 AM
S1lenz
Jun 1, 2009 12:03 AM
rvtech1835
May 5, 2004 06:55 PM
