Warm/hot start problem
Old Apr 24, 2013 | 02:34 PM
david-morton's Avatar
Default Warm/hot start problem
Hi guys,
Having a problem with starting my car when its WARM - doesn't seem to be a problem when its either cold or hot, just in between. So far its mainly been when its done reletively short trips and been left sitting for 15-60 mins (but today was left for 3 and 1/2 hours in a closed multistorey and had the same problem).
It's a 52 plate 1.8 petrol A3. It has around 110,000 miles on the clock but has been well looked after.
After reading threads etc, have changed the engine temp sensor, but have still had the same problem. Have plugged it in and there is no recorded error codes, so seems not to be saving any problems.
Any advice or suggestions?
Thanks, Dave.
Old Jun 22, 2013 | 04:03 AM
Benjo's Avatar
Originally Posted by david-morton
Hi guys,
Thanks, Dave.
Hi Dave,
I can see that you didn't get many replies on this forum regarding your problem, but I was just wondering if you had managed to sort the issue out?
I have an 01 plate 2.0 auto petrol A4 with about the same mileage and exactly the same problem! Really getting frustrated with it now!
Thanks, Ben.
Old Jun 22, 2013 | 04:55 AM
carshow's Avatar
Try checking the coolant temperature sender
Old Jun 22, 2013 | 08:04 AM
Benjo's Avatar
Hey, thanks for the reply.
I changed that first as has Dave above, still the same!
What a pain!
Ben
Old Jun 22, 2013 | 08:29 AM
Hi Ben. I did get it fixed yes, turned out to be the crankshaft sensor, cost me about £100 all together which included code reading it, the sensor and fitting it! Good luck and hope this fixes your problem!
SamAudiA3_2011
Apr 20, 2022 05:46 PM
tonycarp
Nov 10, 2016 09:13 AM
italiaudi
Mar 2, 2013 10:01 AM
Biggilesy
Aug 24, 2012 01:32 AM
J.E.B
May 14, 2008 05:04 AM
