Water from floor vents
I have a 1994 Cabrio. Within the last month or so i have been getting water pooring out from vents under the dash, both side. I can't say i have noticed any puddles under the car after the AC has been running. Can anyone tell me were the AC drain tube exits on this car? Any other suggestions as to where the water is coming form?
Also, does this year Audi also require the special coolant? If you flush the system can you put in standard antifreeze?
Thanks in advance,
Jesse
Thanks in advance,
Jesse
Not exactly sure where the vent is on your car but its probably tucked pretty highup around the bellhousing area. Definalty sounds like a plugged drain with the symtoms you describe. As for the coolant im pretty sure your vehicle take s g11 which is the blue stuff. It might even say right on the coolant reservoir.
