Water from floor vents
Old Aug 1, 2006 | 11:59 PM
jesse's Avatar
Default Water from floor vents
I have a 1994 Cabrio. Within the last month or so i have been getting water pooring out from vents under the dash, both side. I can't say i have noticed any puddles under the car after the AC has been running. Can anyone tell me were the AC drain tube exits on this car? Any other suggestions as to where the water is coming form?
Also, does this year Audi also require the special coolant? If you flush the system can you put in standard antifreeze?
Thanks in advance,
Jesse
Old Aug 6, 2006 | 05:18 AM
dankhound's Avatar
Default RE: Water from floor vents
Not exactly sure where the vent is on your car but its probably tucked pretty highup around the bellhousing area. Definalty sounds like a plugged drain with the symtoms you describe. As for the coolant im pretty sure your vehicle take s g11 which is the blue stuff. It might even say right on the coolant reservoir.
Taggart01
Jul 13, 2010 02:36 PM
mariop
Sep 6, 2009 04:35 PM
ballswell
Jul 7, 2009 01:39 PM
Leslie
Jan 24, 2008 06:42 PM
BryraTodds
Mar 12, 2006 01:06 AM
