weird fuse problem
Old May 2, 2007 | 10:05 PM
ThePapaCMan's Avatar
Default weird fuse problem
my drivers side tail/sidemarker/running light fuse blew out, i think its #23, a few months ago and I had my mechanic replace it since my car was going to be there for new turbos anyway. A few nights ago it blew out again. I open it up and the mechanic had put a 20 amp in when it usually takes 5. I bought a pack of 5, put it in, and it blew as soon as the lights came on. I tried this again with 10, 15, and 20 with the same result. Now, driving home from work mypassenger side, NOT drivers side rear brake light blew out. Any ideas what would be causing this or how to diagnose? I have a b5 s4
Old May 2, 2007 | 10:43 PM
CRAZYHAWK's Avatar
Default RE: weird fuse problem
The wires to the rear lights are shorting to ground. Check with an ohm meter.
Old May 2, 2007 | 11:12 PM
what would i need to take apart to fix this? where is the ground?
Old May 3, 2007 | 12:03 PM
CRAZYHAWK's Avatar
The insulation on the wires might be cut, causing a short. This can occur anywhere
from the fuse to the lights.
Old May 3, 2007 | 02:11 PM
2k S4's Avatar
Make sure there is no moisture in there.
Old May 3, 2007 | 03:19 PM
j4n3k's Avatar
Yep you are probably suffering from a short... Do not put higer amp in than specificated it could damage the wireing and posably causing a fire. ( Thats what hapened to my friend)
Old May 3, 2007 | 09:22 PM
moisture in where exactly? The fuse box or the light assembly. I haven't touched the lights, thats the weird thing. Does anyone know where I should start to investigate?
Old May 3, 2007 | 09:29 PM
2k S4's Avatar
ORIGINAL: ThePapaCMan
In the light assembly. You have to remove it anyway to check for shorts.
sbuerkle
Aug 3, 2012 06:34 PM
mctruth3
Dec 8, 2011 07:44 PM
lizzymom67
May 5, 2011 04:01 PM
jaguar7_7
Aug 22, 2010 11:23 AM
