what engine & gearbox help pls
Hi all
i was originally going chevy with my Minotaur kit car but lack of work has seen my engine fund disapear.
with very good advice from a couple of very good friends i am thinking audi now, A8 4.2
has been recommended for my mid engine car ,(and apparently if i can find a 2 wheel drive manuel then i should be able to drop it straight in), but is this the best option as i would be ok with a 3 litre . bearing in mind fuel prices and availablity.
as far as all the electrics involved with a new engine im way out of my depth but apparently that shouldnt cause too much of a problem.
does any one have any thoughts , any ideas or spec also
were and how is the best place to purchace a good one?
many thanks stu this is the space i have www.asci24.dsl.pipex.com/car/tanks3.JPG
& this is my car www.asci24.dsl.pipex.com/minotaur.htm
difficult to say without knowing the dimensions so I could only guess and why a v8 ( how heavy is the chassis ) and engine size is a matter of weight rather than power or show look what lotus did with the 1.6 engine power to weight ratio being the issue
true , i have no bones with using a v6
but you can see what the car looks like and i had room for a chevy small block.
to give u a little history this is the first kit i have ever built,
the guy that sold it to me has been as good as useless (the car designer) there are no instructions
and i cant get any help from him so im having to figure everything out myself.
i was originally sold a mopar engine from a friend of his that i lost £600 on because i was led to believe it was a chevy and silly me i trusted them.
since this he has sold the rights to build the car to pilgrim so i guess cause i didnt buy it from them im screwed.
i just need a break and a little help at this stage because at the moment im pretty well screwed
so thanks for any help its much appreciated i can assure u
cheers stu
(there is a lot more i could bleat on about but i would just sound bitter)
i just want an affordable modern engine that will be big enough so it doesnt look lame , this car is 7 foot wide
cheers stu
the width of the car compared to the width of the engine bay and the engine bay is more important because of obvious reasons, could it take a 4x4 set up? or FWD only, the car is built so engine bay is your primary concern
i will measure engine bay tommorow
but it can not run 4wd
its engine is at the rear so whilst i say fwd it will actually be running the rear wheels
did u look at my web site ?
cheers stu
cheers stu
