RE: what engine & gearbox help pls
yes to a degree
im not building it as a track car but i would like it to have a bit of grunt hence i was going for a chevy small block but i would like a nodern cheeper alternative ? do u see a problem with using audi ? |
do u see a problem with using Audi ? not really as long as it fits in there and all the bits like the radiator the rest can be made to fit, the engine alone doesn't make an Audi its the whole car your is a concept but I will help where I can because it sounds good and those pictures deserve some gratitude awesome would be a good word:)
the rads arent a problem as they are from a lambo and sit away from the engine bay.
the big question is ----the stud pattern for the Audi engine/gearbox similar or hopefully the same on all models i.e can i marry up a a8 engine to a tdi gearbox ?? any one got any thoughts please |
I doubt it would work;)
why and what other options do i have i really want an Audi
v8 engine with a 2wd manuel box ?? |
you can make any engine fit as long as it will, front of engine with rad to wheel centers then gear shift, without dimensions its a black hole
