When does A/C compressor kick in
Old Mar 1, 2007 | 04:10 AM
SAudi's Avatar
Default When does A/C compressor kick in
I have a 1996 A4 and i read somewhere the A/C compressor dosent kick in until a certain tempreture, is this true and if so what temp. i havent run the system all winter(actually since i got the car) and i know it kicks on but thats in my garage at like 55 degree
Old Mar 1, 2007 | 01:28 PM
Flip's Avatar
Default RE: When does A/C compressor kick in
It should only run if you have the air conditioning on.
Old Mar 1, 2007 | 02:44 PM
GeilKyle2's Avatar
the compressor will cycle on and off based on the pressure reached in the ac system. Anytime you have it on "auto" it willcycle even if it's 10degrees out. Air conditioning takes moisture out of air, compressor also cycles on defrost. So when it's on "auto"it's almost like all time defrost
Old Mar 3, 2007 | 07:40 PM
Spoke's Avatar
Member
Owners manual for my 97 A6 says below 32F the A/C will not kick in. With temps less than 32F, pressing the A/C button on the climate control causes the A/C light to momentarily go on, then off. Also can't use air recirculation in the cabin in temps less than 32F since it requires the A/C to be on and A/C is off below 32F.
Spoke
Old Mar 3, 2007 | 08:07 PM
auditech79's Avatar
Spoke is right, even if you activate the a/c manually or in the auto function the a/c compressor will not turn on below 32F degrees so you won't freeze up the system. Kind of like the emergency release valve when the pressure gets too high, if it will hurt the a/c system, the car will shut it off.
Old Mar 4, 2007 | 02:04 AM
SAudi's Avatar
thats what i thought thanks guys.
xlwjey
Feb 14, 2015 10:06 AM
dasaint
Apr 7, 2009 09:08 PM
Jeff
Feb 27, 2006 06:06 AM
dfera
Feb 16, 2005 05:26 PM
