Wierd turbo sounding sound
Old Feb 1, 2007 | 02:44 AM
SAudi's Avatar
Default Wierd turbo sounding sound
Firstly i have a audi a4 2.8 12v quattro, today idownshifted and starting pulling to pass some traffic out of nowhere i hear a something like a turbo spooling up whn i was at about 3600 rpm i kept pulling and shifted at 5000, when i let off the gas the spooling stoped and was replaced but a light shhh sound, this is not a turbo car nor does it have any gay mods to make it sound like one, to make sure this wasent a random thing i drve the car home, shifting under 3000, pulled into the garage and reved the engine, at the lower revs it sounded like it should, a bit loud due to a muffler leak and cats that have the honeycomb completly burned and now they just rattle, as i reved higher into the band of 3k to 5500 it did infact sound like a turbo spooling and a bov. very soft but this is the best i can describe the sound. what could it be. is it the cats, i know they are burned out but they still rattle and i get backfire when i engine break so it sound kinda like a lamborghini, it hasent thrown a code since the day i bought it, i know there was code that i cleared when i bought it but since the day i cleared it the CEL has never come on, once or twice the engine seemed sluggish and i pulled a code for a EGR valve but it still didnt set off the CEL, this is really annoying me, do i have to be worried, i will be replacing the cars in the spring but is there any harm in running the way it does, avant80@2.6 i know you can provide and answer.
Old Feb 1, 2007 | 03:42 PM
2k S4's Avatar
Default RE: Wierd turbo sounding sound
Sounds like a intake leak, or maybe the throw out bearing.
does the noise change when you push in the clutch?
I do know when the syncroes go out, they make a kind of turbo noise, but you have to be moving (car in gear accelerating) to hear it.
Old Feb 1, 2007 | 03:51 PM
SAudi's Avatar
i doubt its a intake leak, it was definetly coming from under car somwhere between the cats and the resonator, it heard the noise when accelerating and the shhhh when i let off the gas(without clutching in) same thing with clutching in and then just reving the engine in the garage without moving, i really hope its not the synchro, also this may help it made th enoise agian on my way to school but i turned of the climate control and radio and it kinda sounded and felt like something was clogging the exhaust kinda like backpressure was building up, but i could still here a fairly quite yet clearly audiable sssssssssssssss-shhhhhhhhhh.
Old Feb 1, 2007 | 03:56 PM
2k S4's Avatar
ORIGINAL: SAudi
Check for an exhaust leak. The area around it will be black soot.
Other then that I have no clue.
Old Feb 1, 2007 | 04:00 PM
techbod's Avatar
EGR would throw a code but the cats sound like the problem also any leak in the exhaust would cause this sound
Old Feb 1, 2007 | 04:03 PM
techbod's Avatar
you could fit a test pipe which is cheaper than a cat
Old Feb 1, 2007 | 04:16 PM
SAudi's Avatar
exaclty what does a test pipe do, i was planning on getting just some universal cats off ebay and have a local shop weld them on to keep me within emmisions limits. as long as nothings gonna mess up on my cat ill spring im good, i just want to make sure this noise isnt hinting that i got silicon build up or something.
Old Feb 1, 2007 | 04:29 PM
techbod's Avatar
it replaces the cats and gives better performance and better fuel consumption but depending on where you are in the world the emissions could be a problem, its just a make up pipe that takes the place of the cat
Pedja
Aug 17, 2010 09:39 PM
Hasanov
Dec 31, 2008 08:06 PM
The Bishop
Sep 22, 2006 09:00 PM
doberman
Jun 6, 2006 07:12 AM
droo587
Nov 10, 2005 04:03 AM
