window problem
Old Dec 17, 2007 | 10:56 PM
ecjr173's Avatar
Member
Default window problem
Was wondering if i can get a little help. My Driver Side rear window is not going up. It comes down with the switch but does not go back up. I can hear what i think is the motor moving but the window does not go up. I can lift it by hand and the process continues. Down but not up. I have not taken the door panels off to check it out. Is removing the panels an easy task for a newbee to Audi. I have removed the door panels on my civic, but these are two different cars. Any info would really help. By the way its a 2002 A4 1.8T
Old Dec 19, 2007 | 05:43 PM
tHe kNiGHt FaLL's Avatar
Default RE: window problem
window clips... plastic clips that hold the window in place break. i used to fix them all day. pays well
Old Dec 19, 2007 | 08:04 PM
ecjr173's Avatar
Member
Would you happen to have a part number for these clips. Or does it come included with something else that is not needed. How dificult is it to do this repair. keep in mind im a newbee
Old Dec 19, 2007 | 08:21 PM
jgurland's Avatar
Here's one way to do it http://www.audiworld.com/tech/int45.shtml.
I did it on my driver window without completely removing the window, but if you follow the instructions in the link you'll get to the point where you say, "Oh, I guess I can just get to it from here and not go to all that trouble."
Good luck if you try it.
Old Dec 19, 2007 | 11:59 PM
ecjr173's Avatar
Member
cool thanks but this is for a 99 and i have an 02. would the parts be the same
Old Dec 20, 2007 | 06:04 PM
go to the dealer for the parts... they are like 25.00 for the set and they are upgrades from the stock set.
you can do itwithout removing the window frame... all you need is a short torx bit... and i suggest you do it that way too... because the window needs to be re aligned if the frame is removed. and if you don't get it right the door won't close properly.
Old Dec 21, 2007 | 01:11 AM
ecjr173's Avatar
Member
Cool thanks man. Im going to try and get it done this weekend.
Ivan_Chokibich
Jul 6, 2009 09:33 PM
codeman4000
Sep 27, 2008 01:02 AM
fluidculture
Aug 26, 2008 01:23 AM
armani1608
Dec 14, 2006 08:00 PM
audidude86
Apr 25, 2006 05:47 PM
